CATONY
- 0
- 0
- Hermosa Beach
Hello Fellas,
I'll do my best to make a long story short.
I have a 1992 M998 HMMWV with 19K miles. I received the unit in good working condition or seemed to be. After a very light 20 miles around the neighborhood I had a no start issue. I had the unit jumped thinking it was the alternator and needed to recharge. Once I drove around for about 30 minutes I parked the car and it would not restart.
I checked the batteries and one of them had a bad cell, I replaced it. Still NO START. NO CRANK. NO CLICK, NOTHING.
I have read all the posts that relate to this issue which could be the Glow plugs, TSU, PCB or Grounding issue.
No one has mentioned a STARTER ISSUE?
There is a small possibility some idiot in the apt complex messed with the RUN START and left it in the RUN position.
One more thing right before I parked the car for the last time, literally one block from my house there was a loud squeal upon acceleration???
What should I do first?
1. Check Glow Plugs
2.TSU
3. PCB
Any and all advice will be much appreciated. What part numbers do I or should I look to replace?
Where is the best Place to find the parts?
Should I look into any other issues or just start there?
Thanks again and I look forward to hearing from you.
What exact tool do I need to remove the Glow Plugs?
-Anthony
1. Check Glow Plugs
2.TSU
3. PCB
-Anthony
