Noise reduction
Rattlehead
Michigan
Took a pic of mine today. I haven't drove it yet so I don't know about power loss, as too many other projects going on. But in the driveway it sounds much quieter. Not sure I like the look of it...I saved the original stack pipe and welded on the same "stack breaker" flange to it, so it can be swapped easily. It is much shorter than the current pipe with the rain cap. Had to make a new mirror arm bracket that bolts to the cab to extend the west coast arms outward to clear the muffler. I had a medium duty truck shop order it, about $60.
1,827
Rattlehead, does your M45 have the front drive flanges with a lug on them? Any possibility of a pic?
Thanks!
rdixiemiller
Olive Branch Mississipi
I think if you rolled some expanded metal around the muffler to duplicate the heat shield it would look a little better. The main thing that looks out of place to me is the color. If it was flat OD and black camo, it would blend in better.
Nice looking rig! Is that attic box the heater unit?
Rattlehead
Michigan
Ken, here's the pic of the hub flange.
Eventually I will repaint the whole truck, so for now everything I add gets painted the same forest green. The van was gutted when I got it, but it supposedly had a heater up top that exhausts through that stack on the front. The heated air went through a false wall in the front of the van, then down through the underside of the corrugated floor. There was also a couple of vent registers in that front wall that could be open or closed. There was fiberglass insulation in the ceiling and in the front main wall of the van, but NONE in any of the other walls. That will have to change, as this is going to be a Michigan hunting rig!
1,827
Thanks rattlehead! I picked up a set of those hubs NOS. I'm going to try to find one more set of them for my other truck. One day I've got to get one of the purification trucks. That body is just plain cool!
