dilvoy
- 25
- 28
- San Francisco, Ca.
The early HMMWV Halfshafts are the weakest. They upgraded them fairly early on. Early enough so that when the Hummers came out in '92 the upgrade type is what was used on them. They are a direct bolt in for the early HMMWV halfshafts. Rear Medium length both sides. Left Front short and Right Font long. If you look on E Bay a bit, you will notice that the upgrade units have differences to the shapes of the CV housings. There are the 12 K units as well, but you would need to change out the Drive Gear in the Geared hub to use those. They look very different than the earlier two Half Shaft designs. You could do very well with a civilian Hummer/H1 parts manual and a service manual as well. Lots of stuff is the same.
