"O" Ring replacement on M939
Doubled
Jonesboro, Arkansas
Are the following steps a correct procedure for replacing an "O" Ring on a M939 series 5 ton wheel?
If so are steps 6 and 7 in the right order?
Pics would be nice if you have them
Thanks!!
Double D
1. Deflate Tire
2. Remove the bolts holding the two halves of the rim together
3. Remove tire and bead lock from rim
4. Take off the old “O” ring and wire brush the groove where it goes
5. Coat the new “O” ring with a silicone based lubricant
6. Install the new “O” Ring
7. Put the tire and bead lock back on the rim
8. Put the rim back together
If new “O” Ring is to big dip in Cold water over it and if to small dip in Hot Water
ARYankee
31
Benton, AR
So did you get that tire to seal?
I'm curious to know about this as well. Is there a TM and what is the number?
Doubled
Jonesboro, Arkansas
I searched the forum and found a post that had the steps on it. I copied the steps and added some comments from the thread. I just was hoping someone who was experienced at them would chime in.
Welder Sam
Glendale, Arizona
I put the tire on then the o ring. Then put the shallow half of the rim on. May not be right but it doesnt leak.
Im not experienced by any means. Ive only done 6 so far. Hope to get 6 more together early next week
Doubled
Jonesboro, Arkansas
That's what I was thinking. I got the order from the other post.
Thanks for your input!!
