Oil Change For My M923
bowoods
Prescott, Arizona
I need help figuring out how to change the motor oil on my M923. I did look at the TM and didn't see specific enough instruction. I have heard that I may have to detach the whole oil pan or is there a drain plug? Any help would be appreciated.
1,174
Please try to post in the appropriate forum.
Oil change is covered in the -20TM and the lube order.
M35A2-AZ
387
Tonopah, AZ
Yes there is a drain plug in the motor and the filter housing has a little drain plug, if it is a NHC250 motor. If it is a A2 you will only have the motor drain plug.
You do not need to remove the oil pan!!!
After you drain the motor you need to drain the filter housing with the little drain plug in it. Or you will make a big mess.
