Oil Leak from exhaust
Mikey90744
ca
Im no trying to hijack this thread, so tell me and Ill shut up if you feel like I am
the line you fixed (IM assuming the ones on top of the injectors with the Ts in em) what do they do exactly? Ive heard people mention injector return lines, whats the purpose of them???
Heavysteven
11
Hickory Flat Ga
Got the 1/8" tube in and ran the truck. A couple small leaks fixed and she is solid.
Now coming the fun part line from the injector pump to the flame heater pump. It's 3/8" and I got it off with out removing anything. Love my gear wrenches. I hope the reinstall goes smooth.
Also, truck start faster.
JCKnife
46
Kentucky
Steven I've seen your Youtube video also RE the fuel line replacement you did. Is that yellow line rated for handling fuel, though? Specifically will it handle diesel and WMO?
This is a job I need to do probably next spring.
Heavysteven
11
Hickory Flat Ga
It's DOT air brake line. It's been in the truck over a year with no issues. I run diesel and transmission oil with no problems to date.
Got it from McMaster Carr.
