supeman100
- 0
- 0
- Austin Texas
Since we don't know what the work the mechanic is quoting, we can't tell you if that's a good price. Sounds like a lot for fixing one wheel. If he's doing all six, its not so bad.I honestly dont know a ton on working on trucks. I had this truck restored for me. He is quoting me $500 for the work. Does that price sound ok? I would do it myself except i don't know how to do a ton.
thanks again!
Drive it to the shop ONLY, being a bobber, means you MAY only have THREE wheels braking, on dry road will not be to bad, drive knowing that you have a issue, on WET road, it will be REAL EASY to put the truck into a spin.The $500 is just for 1 wheel. Its a bobbed deuce so it is only the rear. I get where your coming from with the 500. If that much oil is coming out should i even drive it till its fixed?
A job takes the fun out of a hobby, because it cuts into hobby time/fun. With this SITE and the PROPER TMs, (which is also here) there is NOTHING that the average owner cannot do on these trucks (especially the older ones) which were designed so they can worked on by a "know everything" 18 year old.What 73m19 said
. The down side is if I don't start doing some of the "big" things myself I may have to get a jobb.
Either pay the man or fix it yourself but the truck is deadlined now.Every time i drive my bobbed deuce a large amount of oil starts seeping through on the back wheels. what should i do? is it gear oil? how do i fix it? Thanks!
