oil light issues can you help?
Ken_86gt
Williamsburg VA
Low oil pressure can also be due worn out bearings or the parts that ride in them. You have cam, main, and rod bearings. To replace the cam bearings you will have to tear the motor apart. Now while you have the pan off to do the oil pump you could take a look at the main and rod bearings. You 'could' go ahead and replace them while you have the bottom end apart, they are not very expensive.
beanman1
in the south
well i have the same oil light issues i have a mechanical gauge hooked up and i replaced the sending unit at cold start i get about 50psi and when warm it goes to about 25psi and after a trip down the freeway about 15 miles and stopped on the off ramp waiting on the light to change the light starts flashind the gauge is reading about 23psi a lil pressure on the throttle pedal is goes away i think i might have it idled to low ill try that and see what happens
