Oil Pressure Gauge
willysmd
KENT. UK
HI Guys
Quick question, what should the standard oil pressure gauge read from and to in the M35 2 and 1/2 ton. i.e. zero to what?? as mine goes from zero to 60 psi and I dont think this is correct.
jwaller
19
Columbia, SC
RE: Re: RE: Oil Pressure Gauge
there are 2 available. 0-60 and 0-120. both must be mated to the correct sending unit on the motor.
1,158
The sending unit can be seen on the passenger side of the block, towards the bottom rear. In this picture, it is visible directly above the flexible exhaust pipe.
Related question, My guage says 0-60 and It has been reading like 15 lbs at idle and 20 or 25 running, so I placed a mechanical gauge on the truck, to my suprise, it read 60psi at idle and just under 80psi at high throttle. Is this normal, did I have a mismatched sender to guage? I guess I am happy I am seeing higher pressure than lower pressure.
jwaller
19
Columbia, SC
sounds like either a mismatch or bad gauge or bad sender. I have a good 0-60 gauge and sender that came off my truck. for shipping I'll send it to ya.
1,158
Also check the grounding of the gauge. Bad ground can cause inaccurate readings.
willysmd
KENT. UK
Thanks for all the info everyone, one last question that has been bugging me, why is there two types of gauges 0-60 and 0-120 surely the engines do not produce differing pressures as such, if my gauge is the former and I produce 70 psi then the needle would be "bouncing" off the stop.
1,824
