oil pressure gauge
TexRdnec
Sinton, TX
i know the high and low end but what is the spectrum range of acceptability?
i run about 60 cold idle and 15 warm idle but i can't recall what i do at certain rpms warm.....
i have a 120 gauge
jwright
Freeman Mo
I was told by Memphis Equipment there is also a oil press. reg on the right side of the block behind the turbo that helps control the oil press. There are some springs that sometimes will break or get weak and will mess with the press.
Westex
El Paso, TX
This is a new one to me, I must confess. Anybody got a pic of this device; is it adjustable; controllable; or what?
TexRdnec
Sinton, TX
i THINK that i've found my problem. or at least a problem.....
govliquidation.
http://i33.tinypic.com/2aaj7yh.jpg
i believe the oil pan was partially blocking the oil pickup screen. i looked and looked for this information so in case somebody is curious later....
the oil pickup is 10" from the bottom of the block and 5.5" from the front of the block.
i'm going to put a new pan up after dinner, new oil and filters and see what she does.
she was running 65lbs cold idle and 15lbs hot idle. anything i should really check out while it's off?
http://i50.tinypic.com/35bgzeb.jpg
Stretch44875
Super Jr. Moderator
31
Tiro, Ohio
I've installed an air gauge in place of the oil gauge, and hard plumbed a line to it. Works slow, due to small line, and a very small hole for the gauge. But it will tell you the oil pressure, with no electric.
On the oil pan, it does not take much of a dent on the bottom on the pan to block the oil pickup.
Dennis
TexRdnec
Sinton, TX
i lied. gained about 5 lbs at hot idle. 20 today. hot @ 2000 rpm is about 50.
figure i'll try a sender swap and see if that makes a difference or not.
