Ok... Back To 11X20 Wheels...
gringeltaube
Staff Member
2,363
Montevideo/Uruguay
Re: RE: Re: RE: Ok... Back To 11X20 Wheels...
houdel said:
....Your thoughts on wheel bearing loading with these wheels - both dish in and dish out?
Shouldn't be much of a problem, specially for most of us who only use our trucks for light duty work.
Dished in or out makes no difference, in either case the new wheels center-line "cuts" the hub about .75 inches from its center towards the outside. I know..., there we have the smaller bearing 392...
But if we think about bearing life there are many factors to be taken into consideration: besides water and other contaminants what really kills the bearings are shock-loads. Now these bigger radials will absorb shock-loads much better. On the other hand due to the larger diameter we have a greater leverage effect on all rotating parts plus spindle, steering knuckles, king pins, etc. The rotating mass is only increased on the front axle. The rears will loose some weight since one super single wheel/tire still weights less than two std. 9.00x20s.
Time will tell if the outer bearings have to be replaced more often....
G.
houdel
9
36
Chase, MI
Re: RE: Re: RE: Re: RE: Ok... Back To 11X20 Wheels...
devilman96 said:
Im sayin roughly $220-230... Maybe a little less...
Sounds pretty decent for a custom wheel. Where are you on a dished wheel for those of us who want the "traditional" look?
The G20 tires - Do they have a tread pattern similar to the Michelin XZL?
