ok i need help pleese... pissing me off!
SmokeyDod
Easley, SC
Is your truck or blazer still original or have you changed it to 12V system? It came 24V which both the starter & solonoid on top of starter is 24V?
SmokeyDod
Easley, SC
Are you saying that someone has changed some things & that you are using a pushbutton to "start" the truck rather than turning the ign. switch? Usually the pushbutton is an indication that someone has converted the glow plug over to manuel pushbutton. Also don't understand what you mean by "you have both 24v posts and 12v posts. Sounds like there could be ???????
SmokeyDod
Easley, SC
yes, you need a flywheel. Also you need someone to ck volts going to starter etc. Do you know if the batteries are hooked up to provide 24V or 12V. You probably know this but just because you have 2 batt. DON'T mean you have 24V.
