- 157
- 0
- 0
- Washington, IA
OK, so here how this played out. I mounted the flasher assembly to the inside of the fender the way it was supposed to be. There were holes already there for it. I then had to do some rewiring on the plug. I originally stated that it was a 2-wire plug, but on closer inspection, it is 3-wire with the ground wire broken off. I figured this would solve my problem. I soldered, spliced and reassembled. Plugged it in, flipped on the flasher...nothing! Then, I read your post and moved the focus inside the cab. I simply grabbed the turn signal assembly and wiggled it around on the steering column to try to establish a better ground. Bingo! started working! Now, I'll take it off and use some emery cloth on the contact places to make that ground work better. This truck sat outside with no top for quite a while...I'm sure this won't be the last corroded contact I have to deal with. It's in the machine shed now, so as long as I have it, it will have a roof over it. Now, I'll move my focus to figuring out what's draining my battery. Thanks for your help!If the turn signals still do not work after that, move on to the turn signal switch. The switch grounds to the steering column, so check that the bracket on the assembly or the worm clamp that holds everything to the steering column has a blank contact surface (you see what I mean when you look at it). If still no go, remove the turn signal switch, open it up (be ready for a little spring to jump out) and gently clean/refresh the contact surfaces with electronic cleaner and emery cloth. Reassemble and try again. If still no dice, fork out $45 for a new flasher control box. Yes, you can perhaps repair the old one - there is a thread on it - but you be the judge whether the work involved is worth it for you.
