- 2,882
- 9,425
- 113
- Alexandria, La
Loud and clear, she's so pretty pretty pretty.Let's see if this works...
- YouTube
Enjoy the videos and music you love, upload original content, and share it all with friends, family, and the world on YouTube.youtube.com
The filter was dry. I pulled the pump and stroked it by hand and it was moving fuel. I am going to pull the valve cover today and make sure the eccentric is driving it and move forward from there, as the last thing I touched in that circuit was the eccentric. It may ha e loosened up.Fuel pump or blocked needle and seat in the carb? My stock engine would just turn off while driving due to crud in the tank blocking off the needle and seat. I was running 2 see thru fuel filters and carrying a few spares for a while. I finally pulled the tank, had it boiled clean and all was well.
However, if it is the actual fuel pump. The diaphram doesn’t like the ethanol in the modern gasoline. A company called then and now makes rebuild kits that work:
https://www.then-now-auto.com/product-category/fuel-pump-kits/
I checked the eccentric and pump, all was good. I got in ot and it ran perfectly.The filter was dry. I pulled the pump and stroked it by hand and it was moving fuel. I am going to pull the valve cover today and make sure the eccentric is driving it and move forward from there, as the last thing I touched in that circuit was the eccentric. It may ha e loosened up.
Was not aware of that. I'll check it! Thank you!Don't forget the tank needs to get air back in as the gas goes out.
Most of the time the gas cap has a selector inside, set to 'open' or 'vent'.
D
