Operation Mighty Mite Miracle
ODFever
Madness Takes Its Toll...
76
Orlando, FL
I ordered the following from Rock Auto:
2 each Timken 27690 large bearing
2 each Timken 27620 large race
2 each Timken 18790 small bearing
2 each Timken 18720 small race
2 each National 410708 front hub seal
The total including shipping was $170. Thankfully, Rock Auto accepts PayPal.
ODFever
76
Orlando, FL
From Doc:
A greased hub and pressed bearing ready to go. I have all the box numbers showing in case anyone wants to work on their own Mite. Other photos are of installed hub front and rear. No rubber boot or front seal yet.
ODFever
76
Orlando, FL
From Doc:
I did some wiring just to do something different. Here are the before and after photos of the main harness that mates to the headlight harness. The wires were a bit frayed so I replaced about a ten inch length back to the good insulation under the tape. I installed the new brake light switch and plugged it in.
ODFever
76
Orlando, FL
From Doc:
These are the hub stops that were missing. One had no stop nut and was welded. Ugh. I didn't see until I was cleaning. aua I ground the weld down and re-tapped. Couldn't save the bolt. There have been some casualties in this rebuild.
ODFever
76
Orlando, FL
I ordered 6 Dorman 13563 rubber tie rod boots on Tuesday. They should arrive on 12/20.
ODFever
76
Orlando, FL
Another update from Doc:
Tie rods removed. The Mite must have hit a few tree stumps in its time. auaauaaua Rods are little bowed. I needed a little help with some heat to remove the adjustment bolts and straighten the rods. Finished the rods with new boots. The adjustment sleeves are fully functioning! :)
The tie rods look brand new, OEM, right out of the box just like everything else he touches on this vehicle. I am eternally grateful for the time, effort, and energy that he is pouring into this restoration. I had no idea that so many components and subsystems needed TLC. When this project is complete, I will essentially have a 56 year 'new' Mighty Mite!!!! :)
:jumpin::clinto:[thumbzup] :driver:
ODFever
76
Orlando, FL
I agree. This Mite will be in better shape than it was on the day it rolled out of the factory. :)
As a side note, I bought 6 new whitewall tires for my Model A. Hopefully this upcoming Saturday will be a dry day (the forecast is showing 100% chance of rain right now). He wants to help me install them and align the front end.
Another Ahab
4,901
Alexandria, VA
You just got to post a pic of Alyssa in her Sunday-best once you got those mounted!
ODFever
76
Orlando, FL
The boot clips that Bensinger sent wouldn't work. Doc, irked but highly motivated, made his own.
First, go to True Value where all the good auto parts are. Buy some piano wire. Good spring steel and make a couple of bends....
ODFever
76
Orlando, FL
Finish the bends, then make another one just like it. The last picture is the finished product in place. :)
ODFever
76
Orlando, FL
I'll post the pictures on your Non MV thread. The current set of white walls are yellowed from age. The new set is nice, bright, and pure white. I can't wait to see them on the car! I have a feeling she'll ride, steer, and stop a lot better with new bias ply tires on all four corners. Softer rubber.
ODFever
76
Orlando, FL
I removed the old seal. It was a leather seal. Too "old school". The new neoprene rubber is superior. I installed the new seal and reinstalled the pitman arm.
ODFever
76
Orlando, FL
I have no idea how Doc pulled the seal out. I copied and pasted his notes and uploaded the pictures that he sent me. I'm trapped at my desk at work 5 days a week, which is 130 miles away from his shop. I haven't seen the Mite in person since I dropped it off last year. :-( I REALLY want to get up to his shop, see the progress with my own eyes, and turn some wrenches. Unfortunately, taking care of my daughter, TaeKwonDo, work, holidays, illnesses, and catastrophic failure of my residential HVAC system have prevented me from making the trip.
Another Ahab
4,901
Alexandria, VA
It's like that isn't it?! Living always seems to get in the way of what we WANT to do.
And, DOH, I forget that the picture is from Doc and not you. I apologize, OD. :doh:
I'm a little slow on the uptake, sometimes: especially when I forget to take my vitamins:
