Barrman
- 2,157
- 113
- Giddings, Texas
I went the serpentine belt route Rich. There were two basic systems from the factory. 1996 or so is when they switched. The water pump plate you got from me is for the V belts. You need the serpentine back plate if you go that way.
Basically, the single thermostat set up had the alternator on the drivers side with the power steering pump and everything else on the passenger side. I have read they had a second alternator bracket for this set up, but I have never seen the parts. I would like to find them for my Cowdog project.
The dual thermostat cross over had the power steering and a/c compressor on the drivers side. The ambulance 2nd alternator option bolted onto the a/c mount. The dual thermostat set up does not allow for the throttle cable bracket/fast idle solenoid bracket you have now. You can make the throttle cable work, but not the fast idle solenoid.
The compressor that goes with the dual thermostat set up is the one GM had on most 2000 and newer vehicles. The one that flexes and leaks in the middle of the housing. Sanden makes a drop in replacement that is supposed to be great.
Going dual air means hose issues. Unless you plan to run two compressors with two condensors? I managed to make a stock dual a/c GM hose set up bolt to a Sanden 506 compressor. That was using GM evaporators.
