- 12,195
- 328
- 0
- gainesville, ga.
I would let soak with marvel and auto trans fluid, and forget for a while, just me, but I would NOT use coke because I would be afraid of etching from the acid, don't think I would use the jack, because you can NOT get the feel for movement, with a bar, you get a hands on feel, check the top end, if good close it up after dumping m/o on everything, if the top is stuck then work each part after a soak, check what is in the pan, drain a bit, if a bunch of, water comes out, drop the pan , check if the mains and rod caps were in water, if good oil comes out, leave it up, WHAT H/S motor do you have, I have a book that covers the 400, 470, 480
