Over 12 Foot Wide Deuce
Heath_h49008
102
Kalamazoo/Mich
Seriously, it would be good to reach out to this poor guy and bring him up to speed. He's enthusiastic and seems like a nice enough guy, who just repeated things he heard from bad sources.
TehTDK
41
Denmark
As a non-owner yet I would actually appreciate if someone knew or had a video/soundclip of how a hydrolock sounded like if such a thing even exists.
Heath_h49008
102
Kalamazoo/Mich
It depends, if you have the shut-down handle pulled it should sound like a "Thunk" as the cylinder stops and the engine stops turning. If she's got the stop handle in, from what I've been told you can't hear anything over the firing of the "clear" cylinders... until it goes "Boom" anyway.
FWIW
If you ever find dead batteries, and the main switch in the "On" position, the chances of a hydrolocked cylinder are much higher.
budman67
Canada (SW ONT)
I have a thread where I asked if a member here could do a video
of the proper starting procedure. I haven't seen one yet.
They guy seems like a likable fellow,but if you are going to put
out a video to inform the masses,you need your facts straight.
TehTDK
41
Denmark
I know how to properly start a deuce, excluding the proper procedure for checking for hydrolock. But remember something like turning the master switch on, but turning the fuel pump off and then trying to crank it over etc.
Heath_h49008
102
Kalamazoo/Mich
Master on
Shut Down pulled out all the way
Crank for several rotations.
If the engine stops suddenly, or does not crank, check battery voltage and connections and check for a hydrolocked cylinder. If the cylinder hydrolock scenario is suspected, pull the injectors and turn the engine over by hand/bar to clear any pooled fuel/oil/water and figure out how it got in there. (master switch left on, bad head gasket, etc)
If the engine turns freely, then:
Master on
Shut Down pushed in to run/start position
Press the start button for no more than 10-20 seconds until the engine starts. (If in cold weather use flame heater or ether start unit as directed in the TM for that unit.)
If it does not start in 10-20 seconds, wait 2 minutes between attempts to allow the starter to cool before cranking again.
When the engine starts, do your standard walk around inspection for leaks, lights and tire pressure while the engine idles for up to 5 minutes and builds air pressure and warms the oil/turbo. Before the engine reaches operating temps, control the idle speed with the hand throttle, and DO NOT rev the engine past 1200rpm.
Not really complicated.
I also like to check the oil level after she runs and then sits for a couple of minutes. It fills the filter canisters and gives me a better dipstick reading. IMHO
If I forgot anything, I'm certain others will chime in...
Heath
