overdrive gears available soon
Kohburn
SOMD
I look forward to progress updates on this - imo definately the best possible way to improve the deuce's road worthiness
frdmdfndr
Hanford, CA
You know, through reading this thread, a lot of folks are worried about the tires handling the extra speed. I'd really rather have something like this for the extra mileage at 55-60.
m-35tom
226
eldersburg maryland
i wouldn't define 3 as 'a lot of people' and 1 of them wouldn't do this anyway! i will say that you probably will NOT see any increase in mpg. in a diesel fuel = power, and more speed = more wind resistance etc. i got 12 mpg at 55 mph with 8000 lbs and slight grades both up and down so they may have cancelled themselves out. i limited the speed because i was doing a mpg study empty and loaded. almost no difference.
tom
m-35tom
226
eldersburg maryland
this is a good time to say thanks to a member who has been a VERY good friend. gerhard, in uruguay, ( gringeltaube ) spent more of his own money than either of us wanted, and also spent considerable time with some of the companies in uruguay trying to help me get this stalled project going again. he did a lot of drawings and was a big help refining the needle brng setup for 5th gear hub. in the end i did end up with a prototype set which proved that the .69 ratio was doable and actually was just the right ratio for the project. we all owe him a big thanks. when these become available, he will be part of the reason.
thanks, gerhard
tom
OPCOM
Dallas, Texas
What of the aforementioned question of 2nd gear spinning too fast on the shaft when the 5th OD is increased? Can you tell about any upgrades to that section?
frdmdfndr
Hanford, CA
Ok, I'll buy that, I'll substitute a few for a lot. It does, however, strike me as odd that the mileage wouldn't change. Unless this wouldn't change the RPM at cruising speed. Seems to me that if you lower the RPM at cruising speed, your mileage would increase. I do know, however that a diesel engine is a mad scientist and sometimes you just never know until you try something. You are the gear man, I'll gladly take your word for it.
R/
Chief Out
jwaller
19
Columbia, SC
although the rpm's come down the load goes up. so you end up having to put your foot into it more. ie more fuel. so as tom said it cancels itself out.
I ran into this issue driving a powerstroke one time. I drove 60mph thinking I'd get better mileage. nope. it took way more pedal to keep it running 60 than it did to run 75. so I sped up to 75 and got better mileage. it's all about load and where your engine makes enough torque to keep the mass moving at speed.
mudguppy
15
duncan, sc
:ditto:
i believe this is perfectly stated, especially the part about your engine's power band relating to the desired operating speed.
m-35tom
226
eldersburg maryland
patrick, go to the web site, there are pictures. 2nd gear is now on needle brngs. actually it is the shaft spinning too fast relative to the gear speed that is the problem.
tom
gringeltaube
Staff Member
2,655
Montevideo/Uruguay
this is a good time to say thanks.........
Thank you, Tom! For your patience and for never giving up on this very ambitious re-engineering project, even after so many drawbacks...
Guess we both learned the hard way how to NOT make gears!?
So you can sell quiet gears now, while I can finish writing my book and hopefully sell some, too......LOL
Good things take good time....,and this took real long so it must come out - not good - but excellent!! ...and there are very good signs of it, already!
Let all the worries and extra-time invested be "for the good cause"!!!
Gerhard
gringeltaube
Staff Member
2,655
Montevideo/Uruguay
LOL...... exactly what I mentioned above: the lessons learned regarding HOW TO NOT MAKE (or have made) GEARS............! (cusses in German language only... :p)
G.
m-35tom
226
eldersburg maryland
finally got the final drawing for approval from forest city gear. should now be only 5 weeks for first 25 sets. anyone interested should reconfirm for first shot at these.
tom
cjtroutt
CW2 26 BDE HHC S6
C.G. JMTC MICHIGAN
To me I would to say Hats of to m-35tom very nice job to get that work through the planning stages to production.
I book marked it.
Thank you very much CJ Troutt.
