Papabear said "I'm getting worried about you"
4,966
I would just have a shop make a set of springs for it. Also, it would be easier (on the eyes) if you drove out from under that trailer bed and added a cut down deuce bed. That would take care of that centered in the wheel well problem.
Why springs? These are fine. 6 bolt holes (reusing some existing ones) and the axle will be centered of the wheel well again. No need to spend more money when time is all it costs to fix. I agree that a cut down deuce bed looks better, but again, I have no deuce bed. Plus this 105 has the sides, bows, and cover.
dirtyfingernails said:
I was headed south from atlanta (I75/475) and think I saw you headed north--today (Sunday) right?
Yup that was me.
walkerhunter said:
I like it just needs the hubs flipped!
On the to do list. As well as 395's, and recentered HEMTTs or PLS wheels.
DUG
Senior Chief/Moderator
73
Mesquite, NV
Yup that was me.
Springs would make it ride correctly without blocks. M105 beds look (censored).
Just my totally unsolicited, unrequested and probably unwanted opinion that is most likely completely true. Unless it isn't.
4,966
I happen to have two more wheels and tires...
Once the driveshaft is lengthend and the axle is set back, I'll throw them on. Or I might before. I can't stand seeing the drums on the rear axle.
A locker would be nice for the rear as well.
I wish there was something taller I could run in duals for a little easier cruising speed.
4,966
It drove 150 miles today and the rear suspension wasn't a problem at all. The blocks aren't that bad either. Guy thought it through. I'll snag a pic of them. The U bolts are captured in the bottom of the block as well as the top, then by the plate at the springs. There's NO way these could be spit out. I even drove it around this afternoon (to test the clutch) on the fire service road behind my house. Flexed around there no problem.
Course then again, I kinda expected to get all sorts of flak about a bobbed deuce. But then again, I don't care. fat lady sings
3dAngus
101
Perry, Ga.
I like the wheel well look the M105 gives better than the straight line of the deuce bed on a bobbed truck. I understand opinions vary, but this is the way I want to do it. I see you already have parts on order Patracy. Good luck and be sure to take pictures and share along the way.
This is one I gotta see.
islandguydon
787
Michigan
I agree with Dell, Heck I will even donate the 105 box in 100% pristine condition for the mod if you want to do it. It would be an honor, I will even throw in the LED taillights as well.
DUG
73
Mesquite, NV
Glad I'm living up to your high expectations.
Enjoy the bobber. Look forward to updates.
4,966
Despite the bad paint job, the 105 box on the back is an 02 model and in good shape.
4,966
I glanced at the front, I should be able to make some "leafs" for the front since the U bolts are long enough. That'll help level it out and add a little more clearance for larger tires as well.
m816
Chatham, NJ
Looks like Bobbers are finally getting accepted on this forum. Not one derogertory remark. Even I am helping build one in the shop now. I never thought I'd see the day.[thumbzup]
73m819
327
gainesville, ga.
I am a MOD so I can NOT say my bobber thoughts and how thay are a very small step above a cucv. :roll:
