Park Brake Pop
SuperchargedRS
palm springs
I recently noticed that when I try to engage the parking brake the pedal does not go all the way down all the time (this just started occurring), I also noticed a slight noise in the rear end, almost like there is something rubbing inside the drum.
Under normal operation the brakes seem to work just fine otherwise, I can not see anything externally wrong with the brakes or lines...
Any ideas???
Thanks
-SuperchargedRS
SuperchargedRS
palm springs
I am not too sure what happened, the park brake and driving brakes are still ok, and I think the noise is a unrelated right rear shock cover (one of those crappy OEM shocks) rattling around, soon to be replaced.
TheBuggyman
Fredericksburg, Virginia
Re: RE: Park Brake Pop
Recovry4x4 said:
Get those drums off quick. Sounds like a hold down or something let go.
DITTO!
Cannot hurt to look, even if it is the shock making the noise you stated an inconsistent response when applying the parking brake.
Sumptin' ain't right!
BKinzey
Hollywood, CA
Maybe he is smart enough to use his parking brake and wants it to work. :roll:
That's beside the point though since it's use is telling him symptoms of potential problems.
mangus580
283
Western NY
I use mine faithfully for just that reason... worked when I got it 2 years ago, so I forced myself to get in the habit. Now I even set the one in the wifes car alot too....
CCATLETT1984
Saint Clair Shores, MI
I am losing the parking brake with the rear disc conversion. I will end up getting a line-lock for the rear line to keep them applied when I need the parking brake. I will prolly get a manual one with a lever and just engage it when needed. I'm not sure if i trust the electric ones.
