SteveKuhn
- 4
- 0
- Hasbrouck Heights NJ
I'm trying to remedy a too-tight adjustment that dates back to swapping my transfer case. Seems all the adjustment was done at the cable and arm and the inner shoe was dragging.
I'm trying to go through the TM procedure but my cable is older and there's no clear 'start mark' where they say to begin the adjustment. Also, the transfer case was a factory reman and it seems that the adjuster bolt was run in with a gun to the shoulder and likely painted over. I haven't managed to get it out yet even with moderate heat directly on the arm it threads through. I'm concerned that the head is at least a bit buggered and if I need to pull everything apart to get it right, I'd like to replace the bolt.
1. Can anyone give me an approximation of how far from the end the lever & jam nut should start for the adjustment (highlighted arrow)? It's up close the cross member but there's room to work.
2. Can anyone provide the correct highlighted bolt size? I hope it's standard.
3. I actually considered putting a nut & washer on the outside of the fully-in, frozen bolt to use for adjustment. Not my 1st choice but I'm wondering if it has been tried.
The top of the outer shoe is not standing off far enough. It's close on top and 'way out at the bottom. Running the lever in on the cable just exacerbates the inner shoe pinching.
I'm going to need to move the lever back to the right spot on the cable and start from there.
BTW, a ratcheting flat wrench on the cable nut works OK as long as I hold the cable under the boot with a 5/32 (I think that's what it was) .
Thanks.
Steve
Thanks.
Steve
