- 10,350
- 92
- 48
- Meadows of Dan, Virginia
Mike, thanks for the clearification of "je", should be more careful about reading.
Here are the images for the light bar. The pipe is 2-1/2 inch dia steel, made in 3 pieces. The aluminum angle on top holds the lights as you can see.
Should work for any cab top and not be in the way of the cargo cover or the cab canvas/hard top.
(The cab top on my deuce is only a cover for the bikini top, used when the truck is parked, that the reason for the "loose fit").
