Thanks guy's.. Here is what the guy claimed in the ad:
You are bidding on a ONE OF A KIND built truck. This truck started as a clean M35a2 military truck and was converted into the monster you see here. The truck just went through a motorpool spec restoration and has all new paint inside and out. The bed cover is new as well. I drove it around and the truck starts right up and runs/drives/stops great. It is powered by the turbocharged Continental LDT-465 multifuel Diesel engine. It has a 5 speed manual transmission with the air locking transfer case. The Rockwell axles have a 6.72 gear ratio so you can climb over anything you want. There is no stopping this truck, it really is awesome. The truck is showing 22k miles and 800 hours so it has just been broken in for you. This truck has been checked out and is in great running order with no issues or leaks of any kind. The tires are Michelin 14.00 R 20's which is 49" tall x 15" wide mounted on military double beadlocks. They are huge! I have other wheels and tires, winches, etc that are available so contact me if you are interested.
If you want the biggest baddest truck on the block this is the one for you! The truck actually gets a decent 12-14mpg on the highway and you can even run 50-75% used motor oil if you want. We can assist in locating a shipper for this truck and it should be somewhere between $500-1200 depending where you are located. If you have a car, truck, Jeep, motorcycle, boat, ATV, motorhome or ? you are thinking about trading let us know and maybe we can work something out. If you want a truck custom build let us know! If you have any questions feel free to ask.
Before I got it off the truck you could see the usual leaks from an old truck everywhere: Oil pan, fuel control, transfer case, transmission, rt brake drum, rt headlamp inop, rt wiper inop, missing some lugnuts, parking brake inop (out of adjustment), various air leaks, old fogged up mirrors, and rust everywhere.
Going to call the guy now and be nice and see what he will do to correct any issues. I do not want to say who the seller is, because he might be willing to work something out.
I do know that I went out and purchased the MOST expensive bobbed truck I could find not to have any trouble with it right off the bat. If I wanted something to work on as soon as I got it home I would have made my first purchase from GL.
Rutledge
"In a Rut"
