- 1,774
- 2,431
- 113
- Rosamond, CA
One for the left side and one for the right side tires.I don’t know why the air blaster is in there twice.It only shows 2 pics when uploaded but I see 3
What are we blowing up today?
They are back in stock at Simple, at nearly a $100 increase over what you said you paid, jeez just can't get a break...My petlas came in today. look good, DOT 0824, so, lots of life. $390 ea shipped from simple tire.
Look like i will NOT be installing the bead locks, sorry for your troubles Mogman, thanks for the write up.
I am not yet sure the plan with balancing them. I own a balancer, i remember a few of my rims being off by several OZ with NO TIRE. with the bajas, they were calling for 16+oz... I used both beads and rings.
I may try to pick up a set of 24 bolts for the petlas install
Price does fluctuate quite a bit. I've actually check simple tire probably weekly, since before this thread started.I need a sugar mama![]()
Yea, I put one in my cart om their web site, will do the same on fleabay and see if they make an offer.Price does fluctuate quite a bit. I've actually check simple tire probably weekly, since before this thread started.
I actually did buy them from their eBay store, I had them in my cart for over a month, and then I got a push notification that the price had been lowered. That's what pushed me over the edge to actually buy them since previously I've been going back and forth with just getting another set of baja takeoffs
Right now I can't find a decent deal on the set of 24 bolts. I kind of want to install these on a new set of rims instead of my old 12 bolt
My local guy does not have any, there's one guy selling some sets on ebay, but with shipping you're looking at 500+ bucks for four
How wide are your TWF PVC spacers?Yea, I put one in my cart om their web site, will do the same on fleabay and see if they make an offer.
I think they are marked 8.75" I will measure one to make sure, sorry about the late response, I do suffer from CRSHow wide are your TWF PVC spacers?
I went to install the tires today and put one of my 12 bolts rims on the balancer by itself... Nope
- YouTube
Enjoy the videos and music you love, upload original content, and share it all with friends, family, and the world on YouTube.youtube.com
I ordered a set of 24 bolts from feltz
Trying to decide on inserts. I'm can get local rubber ones for $10, TWF will cut some PVC ones to custom size, or go with no inserts like I have for the past few years
I think I fixed it!Well there’s always this it blasts a lot of air to fill the tireView attachment 927114
Or one of these that fills the gap between the tire and the bead and just pushes off when the tire is fully inflated. ( my fave next to starting fluid)View attachment 927115
I like using the soap, I have been doing it long before those blasters ever became popular, besides you have to get the can of soap out anywayThat’s my fave. The blaster works but may take a couple of try’s , plus if ur not holding on real good it can tak off like a rocket.
Curious, did you check the rim for radial runout? Does the mounted tire have any radial runout?Good news, they look amazing on the paired 24 bolts, bad news is, my balancer says it wants 17 Oz... Dangit
Well little updateCurious, did you check the rim for radial runout? Does the mounted tire have any radial runout?
Post 46 had them mounted on 24 bolt paired rims, yes they look great!!
I wonder if you are not having the same issue with the factory run flats as I had with the TWF bead locks.Well little update
Yes I checked the rim for runout and its very minimal.
But when the tire was on there, there was a very noticable run out.
This morning, I checked it again and it's down to needing 9oz and the run out looks less.
Weird?
My hunch is the tire is deformed due to shipping, storage etc
So I inflated it to 55psi and stuck it out in the sun. Fingers crossed
so I decided to try a few different configurations. I've read it's extremely hard to remove the run flats one installed, so for this first try, I installed them without the run flats.I wonder if you are not having the same issue with the factory run flats as I had with the TWF bead locks.
It would make more sense that the bead was "slipping" out from under the run flats influence than deformed due to storage.
Did the rim halves go together without much force from the nuts, or did the halves need to be "pushed" together by the nuts?
That is bad a$$All installed. All balanced to Zero (needed 9, 4, 5 and 6.5oz)
No inserts, No beads, i left the hummer rings off for now, and it rides pretty smooth up to 70.
ThanksThat is bad a$$
