This is my fist experience with the MEP-802A units (or any MEP units for that matter). I've been looking for an alternative to my 3600 rpm civilian screamers (Generac 8kw and 15kw LP fired sets), which I just sold. I came across an ad on CL from a guy that had 4 for sale between $400 and $1000. I picked up 3 of them for a total of $2000.
EDIT: I ended up getting a total of 5 MEP 802As from Dean in MD . Also picked up a 803 in January of 2021. This thread will document the journey of (hopefully) getting them all up and running and the various challenges along the way. The 803 came on a M116A3 trailer, which is my first military trailer of any kind.
All of them had this same sticker on them:
![802A-2006-02.jpg 802A-2006-02.jpg](https://www.steelsoldiers.com/data/attachments/341/341081-e95137616477816e06ed9f6b42d87e3c.jpg)
All 3 units were fairly new (2006, 2007 and 2009). The 2007 unit was refurbished in 2010 at camp Arifjan, Kuwait. It is showing 1355 hours. The 2006 unit has 3544 hours and the 2009 2844 hours.
Here they are on the back of my truck when I got them home.
![MEP-802A-ALL-01.jpg MEP-802A-ALL-01.jpg](https://www.steelsoldiers.com/data/attachments/340/340824-76cb2c44529c7964e94bf01fdf139cab.jpg)
After unloading them I proceeded to drain whatever was in the crankcase of each one. The 2009 had the exhaust flap intact and all I got out of it was a little bit of engine oil as seen here.
![802A-2009-05.jpg 802A-2009-05.jpg](https://www.steelsoldiers.com/data/attachments/341/341082-b4f43ef2afe8ea271358b0c7bcee7611.jpg)
The 2007 genset had maybe 1/4 cup of water in it and the 2006 about 1/2 cup. So way less than the several quarts I know some of you guys have experienced. I suppose I should consider myself lucky.
Going through each one, starting with the oldest one first, here are my findings/detailed pictures.
2006 unit:
![802A-2006-01.jpg 802A-2006-01.jpg](https://www.steelsoldiers.com/data/attachments/341/341083-17f46dd2316575f0c267274ed53ae6a2.jpg)
All gauges are present and all switches appear to be functional. Not sure if it is normal for the fuel, coolant and oil pressure gauges to read random values (the same gauges on the other 2 gensets are showing different random values).
![802A-2006-03.jpg 802A-2006-03.jpg](https://www.steelsoldiers.com/data/attachments/341/341084-62cd4fd6f68f283842b46e6357f73a8f.jpg)
http://www.cstone.net/~dk/802A-2006-03.JPG
One concern with this unit is that the front top cover over the electricals is missing and there is a lot of corrosion on the terminals as seen in these pictures
![802A-2006-06.jpg 802A-2006-06.jpg](https://www.steelsoldiers.com/data/attachments/341/341085-1ed9d03e9ae4eecf8303af373423b7d5.jpg)
![802A-2006-07.jpg 802A-2006-07.jpg](https://www.steelsoldiers.com/data/attachments/341/341086-b255ea4b587c6131edf63523c0da71f5.jpg)
http://www.cstone.net/~dk/802A-2006-06.JPG
http://www.cstone.net/~dk/802A-2006-07.JPG
Moving on to the engine, I think it looks pretty decent. The secondary fuel filter cap is present, as is the air filter end cap and oil filler cap. There's just 1 wire here not connected to that can hanging down below where the fuel pressure sensor/switch or whatever it is.
![802A-2006-09.jpg 802A-2006-09.jpg](https://www.steelsoldiers.com/data/attachments/341/341087-20a2b16a18dd154987d02e57e6725c98.jpg)
http://www.cstone.net/~dk/802A-2006-09.JPG
On the other side of the engine, I'm noticing that all the coolant drain lines are missing, but that should be easy enough to fix.
![802A-2006-10.jpg 802A-2006-10.jpg](https://www.steelsoldiers.com/data/attachments/341/341088-ff2b268eee42195dc8c90e13a7ca1f03.jpg)
http://www.cstone.net/~dk/802A-2006-10.JPG
Next I removed the injectors and dropped in 1.5 oz of ATF.
![802A-2006-INJ-01.jpg 802A-2006-INJ-01.jpg](https://www.steelsoldiers.com/data/attachments/341/341089-04265d57217e914f93f5d57d2a3c7515.jpg)
http://www.cstone.net/~dk/802A-2006-INJ-01.JPG
EDIT: Well I guess that's what I get for working on these things past midnight. I believe those are actually the individual fuel pumps for each cylinder. So I dumped ATF and PB into the crank case instead of down each cylinder. That in itself did no harm, but this morning I went and turned it over with completely dry cylinder walls...
Unit | Acquire Date | Build Date | Hours | Cost | Engine ID Tag | Condition |
MEP 802A #1 | 6/2014 | 07 2006 | 3544 | $400 | 44020385DN2WA72 | Water in bores |
MEP 802A #2 | 6/2014 | 06 2007 | 1355 | $600 | 44006095DN2WA72 | Water in bores |
MEP 802A #3 | 6/2014 | 08 2009 | 2844 | $1,000 | 081028765DB2WA72 | Water in bores |
MEP 802A #4 | 10/2014 | 07 2009 | 3504 | $1,200 | 081028775DN2WA72 | Engine cranks |
MEP 802A #5 | 10/2014 | 08 2008 | 7502 | $800 | 081019635DN2WA72 | Cracked piston |
MEP 803A #1 | 1/2021 | 07 2000 | 5717 | $5,000 | 0006800210DN4WA72 | Makes power |
2006 unit:
