Pics of my singled 5-ton with 16-20's - just finished!
littlebob
26
Baton Rouge LA
RE: Re: RE: Pics of my singled 5-ton with 16-20
Very Nice! I want one too. but by the time I finish my deuce I probably won't be looking for another project for a year or two.
dma251
Arlington, Washington
I took it out for it's first run on the new rubber today. Feeling kinda nervous about it, so I dropped by my local Les Schwab tire center and had them double check the wheel torque and air pressure (450 ft/lbs, 90 psi). All okay, so I headed out on the highway. The ride is a little bumpy when you roll off from a stop, but after about 10 mph it smooths right out. It felt so good, I jumped on the freeway to run it up to speed. I ran it up to 75 mph smooth as can be and tracking dead-on straight. I only held that speed for a minute to see if I could do it, and then dropped down to about 60-65 mph. At 75 mph (according to my GPS) the tach was at 2000 rpm and the truck's speedo was indicating 57-59 (it bounces).
At a more comfortable 65 mph the rpm was around 1750-1800 rpm, and the speedo indicating 45 mph.
This truck is so easy to drive, you can take your hands off the wheel and steer with your knees! The bigger tires were a great improvement - plus I get more looks then ever before! This thing really REALLY sticks out on the road!
Deuceswild
Sheboygan WI
dma251,
Just curious, but how much clearance is there between the rear tires? Would love to see some video of that monster in action, ( Hint-Hint :lol: ),
Again, Great Job!
Jeff.
dma251
It's funny you should say that, I took a video of it today that really shows the rear clearance well, but it's pretty big (20 meg and 31 meg). How do I post these?
I tried adding the 20 meg video to the video gallery, but I got this error message - "Missing argument 'tid' in 'pagesetter_adminapi_getPubTypeInfo'"
Anyway, to answer your question - it's got a lot more clearance then you would think.
builder77
Damn your house looks small in those pics. Nice ride.
rizzo
Port Huron, MI
I have 2 five tons with 1600's. clearance inbetween the two rear tires is 1inch +-.
dma251
That's no concern to me - what I was worried about was the vertical clearance of the the axle into the cargo bed - which proved to be no issue really at all. If I could figure out how to post this video I would show you....
M1075
Oklahoma City
Re: RE: Re: RE: Pics of my singled 5-ton with 16-20
No clearance issues with the bed? What about with the axles on the bump stops (i.e. big load, off road)?
rizzo
Port Huron, MI
RE: Re: RE: Re: RE: Pics of my singled 5-ton with 16-20
I'm prety sure they have rubbed on my M543 I put a deuce bed on my M810 and ended up putting a 5.5 inch lift on the bed so they don't rub.
dma251
sure wish I could show you guys my videos... I tried once again today to upload them.... Anyone know how to reduce the size of an mpeg? If I get it under 10mb I can email it out.
Like I said before - I drove the truck down a 45 degree slope about 6 feet deep and didn't rub the bed. There were no rub marks on the crossmembers at all. I'm sure if I somehow stuffed the axle further up there I could get it to hit, but I think for most guys that's not likely.
I'll still do the 2" bed lift, but now I realize it will only be for cosmetic reasons. It's just too darn easy looking to do...
1,163
Upload it to google video or youtube, then link it here.
dma251
Success! I have one video on YouTube, and the other will be up in a few minutes.
This is the best I could do by my house to twist up the rear suspension - The reason I did this was also so I could load all the old tires up in the bed by rolling them into the back on a plank from the street!
I'll post the other one in a few minutes.
http://www.youtube.com/watch?v=eV_07EGI9FU
builder77
I am curious about this bed mounted crane you installed. Is this the type you can buy from Northern, or something special? Any pics?
dma251
Well, it's not very "extreme" at all, but it does a good job of showing that 16-20's DO provide enough clearance for average offroad use. Case closed.
I'll put some pics of the bed crane up tomorrow, but it's basically the Harbor Freight model braced to the bedside. I'll paint it ASAP! Orange aint workin'....
builder77
dma251
First one - It'll get high enough to drag my spare up and down from the bed. That's all I really needed. It looks okay. I haven't even used it yet, but I'll let you know how it turns out.
