PLS info/measurements.
hot rod deuce
Kasota, Mn
Hey guys,
I'm wondering if any one has access to a PLS, It needs to be the 1075 type with 5 axles,10 wheels. I'm looking for some measurments of the axles.
I can bribe you with tank driving and machine gun shooting if you swing by.
-Tony
gringeltaube
Staff Member
2,269
Montevideo/Uruguay
Hey, glad to see you again...!
I don't have a M1075 near by but I can answer your last Q: Same as HET; 10 on 13.2"
G.
bikeman
501
Ft. Bragg, NC
Axles on all HEMMT series trucks (true HEMMTs) are the same. What's your overall question? the axles or the entire truck measurements (IE shipping?)
paradeduty
Chelsea, Michigan, U.S.A.
Sorry Bikeman, I have HEMTTs, LVS, PLS and HET - the only ones with the same rims are the PLS and the HET. I think the HET has a different hub planetary gear set-up than the PLS (to handle the much greater GCVWR and ending up with a 45 MPH maximum and a 8 1/2 foot width). That means that all four of the mentioned HEMTT "variants" use different axle assemblies.
bikeman
501
Ft. Bragg, NC
Well crap, I never had to go into the axles, just replacement tires/rims, guess I didn't look close enough. I know the A4 PLS we were fielded had a different setup but that's all I recall, guess I should have paid closer attention. Thanks!
