Plunger on front of 6.2 injection pump
mutt1966
13
Allentown, PA
Iam in the process of replacing the injection pump on my M1009 everything is going smoothly, when I removed the old pump on the front of the pump were the three bolts arethat holds it to the gear theres a plunger (lack of a better name) seems to be spring loaded the rebuilt pump is missing it anyone know what its for and how do you remove it so I can put on the rebuilt pump. Thanks for any help, Scott O&O
mutt1966
13
Allentown, PA
thats what I tought but it seems to be attached to sometning feels like a spring if you pull on it, it snaps bak if you turn left or right it sprigs back maybe not pulling hard enough just afraid to screw it up. Thanks, Scott
jets1959
9
Lakewood, WA
Try pulling it out a little bid and then turning it first one way and then the other to make the spring inside shrink a little. When I did mine the spring stayed inside and I had to use a small ninty degree scribe to get it out. I just threaded the scribe all the way down until it too came loose. Good Luck!!!!!!!!!!!!2cents
jets1959
9
Lakewood, WA
Glad to be of service. People on here have helped me out and am glad just to return the favor!!!!!!!!!!!!:beer:
