Amer-team
- 55
- 48
- Centralia/WA
Looks like a go for me. May bring the amublance since I haven't hardly driven it since our last hamburger run. Besides it does 60 and has a heater.
Sorry to hear it, if I lived closer I would be glad to pick you up and bring you back!Thank you, but it is not the lack of a MV that I would trust to drive that far it is a lack of funds to pay for the Gas.
Hello my friend, long time since we have heard from you. Hope your wife is much better!!! Most of us are now on face book. Search PNW Steel Soldiers! If you request to join I wii confirm you. Just let me know your face book name. Happy new year to you and yours! DwayneHi all.Just want to say I'm still here.I've been busy helping my wife recover from her injury,but that does'nt mean I'm not participating with the Steel Soldiers Spirit!
My AmGen Duece was able to pick up my wife's new wheel chair lift equipment last week from a GL auction.Brand new!Bargin price!
Cheers to all and a happy new year...REO
Hi Dave,I'm not participating much either, but all I would add is hope and pray that your wife improves day by day and our prayers and thoughts are with both of you in this road to recovery which will happen. God Bless and Happy New Year to all on SteelSoldiers! elkhunterHi all.Just want to say I'm still here.I've been busy helping my wife recover from her injury,but that does'nt mean I'm not participating with the Steel Soldiers Spirit!
Have your old shoes relined at south south brake and clutch!Well, one of the brake shoes seems to have been damaged. Shortly before I took it for a test drive around the block I had a friend look at the back of the drums as I pumped the brakes, and the wheel cylinder blew out again. Same one as last time, but it looks as though it was due to the shoe bending.
Ordering a new brake shoe on Thursday I guess. Do they have to be replaced as a pair? They dont look hardly worn at all. Also, is there another place to get the shoes from other than eriksmilitarysurplus.com? I dont suppose Napa has them?
How are you and your family doing, elkhunter? Hope all is well!! Can't wait to meet up with all of you again this year at Aaron's. take care and be well!!Hi Dave,I'm not participating much either, but all I would add is hope and pray that your wife improves day by day and our prayers and thoughts are with both of you in this road to recovery which will happen. God Bless and Happy New Year to all on SteelSoldiers! elkhunter
e
The only issue is that the shoe is damaged where the wheel cylinder pushes against it. None of the Shoes look worn out though.Have your old shoes relined at south south brake and clutch!
Rapid brake, and a heavy truck shop on Pacific hwy, I will check those both out.Loco, South sound brake as already mentioned or Rapid Brake in Olympia. Also if you go to a heavy truck parts shop, they may be able to hook you up. I think there is one on old Pacific Hwy. in Fife. You might also catch one at Brad's in Yelm, depending on what he has on the scrap pile. The nice thing about going to some of the major suppliers, is that when you ask, they know what you are talking about. On the reverse, if you can get it locally, you usually save shipping and sometimes the item cost is about the same.
What sort of damage could you have where the wheel cylinder pushes against the shoe? Can you do a picture? I might have gotten a wheel cylinder on the 5T that the gap was too narrow and it wouldn't release from the shoe, so we substituted the old push rod and it worked fine.
Trying to repair it will not work, I know because I already tried it. It failed again, blew the Wheel Cylinder apart, and here we are.I would NOT repair the bent shoe. In my opinion, unsafe. Could cause a wheel lock-up if it bends again, or fatigues in the future.
In 50 years of working on vehicles, I have only seen this happen a few times.
What I saw - The push rod pushed on the shoe at an angle because one of the hold down pins corroded and broke. That let the shoe shift away from the backing plate, and rub on the inside of the drum.
The side force on the wheel cylinder caused it to split.
The only time I have seen a wheel cylinder split is where it got side force on it - shoe displacement, ear on pushrod breaking off because replacement shoe was too thick.
I have seen lock-ups and ruptured drums from parts coming loose and getting stuck, overheated lining coming off shoe and getting between lining and drum on other shoe.
I always see how the shoes fit the drum curvature before I install them, and check drums for bellmouthing. A bellmouthed drum can cause the shoes to cock and line up with the bellmouth when the brakes are applied. This would cause the ear on the shoe to be out of line with the wheel cylinder piston, creating side force.
Look carefully and you should find the problem. Replace anything in a brake system that does not look perfect. The extra bucks are cheap versus needing a commercial tow or you or your truck getting damaged, or someone getting hurt.Trying to repair it will not work, I know because I already tried it. It failed again, blew the Wheel Cylinder apart, and here we are.
If you wouldnt mind telling me more about checking the shoe for correct fit inside the drum and checking for "Bell mouthed" drums, it could save me significant headache in the future. Thank you.
Bell mouth - rubbing surface of drum must be parallel to axle. Drums should be cleaned up when new shoes are fitted. If you look inside, you will see the wear area and ridges on either side with rust, where the shoe was not rubbing. The entire wear surface should be cleaned up by taking a light skim in a brake lathe. The replacement shoe may track in a slightly different spot.
The drum must be carefully centered in the lathe - dirt cleared so it runs true when refitted. You can use a dial indicator or take a light cut. If you see that the cut is not uniform, then there was bell mouthing. This can happen from overheating and when the drum is worn to near it's wear limits.
Any wobble from a bent or warped drum will be readily apparent.
Automotive machine shop or truck repair facility should have lathe and brake shoe grinder.
Checking for correct fit - place the shoes inside the drum. the entire lining must contact the rubbing surface evenly. If it does not fit right, and is high in the center or at the ends, it should be contoured to fit in a brake shoe grinder. If just part of the shoe contacts the drum, the brakes will not be as effective on that side. The small area will overheat, and the brakes will not be as effective.
You seem to very knowledgeable about this, is there going to be any harm from replacing just the one shoe, or do I need to replace both shoes in the drum?
If the failure occurred soon after shoes replaced, and the new shoe has the same brand lining, I would just replace it. Always want the same brand linings on both sides of the axle so the brakes are uniform. Different brands can have different friction coeficients and cause pulling to the side under hard braking.
The cause must be found, you do not want a wheel cyl blowing when you have to brake hard braking on the road!!!
Make sure the wheel cyl push rods engage such that they push parallel to the wheel cyls. Since you have had trouble, check the backing plate for distortion and excessive wear. The contact surfaces on the shoes should move smoothly on the backing plate contact surfaces.
If someone used a lot of force to remove a wheel cyl, it is possible the backing plate is distorted where the wheel cyl mounts, and it no longer mounts parallel to the backing plate.
If a shoe has dot 5 brake fluid on the lining, I would not use it.
Thanks for the help yall, this is a weird issue...
