Polaris MRZR-D4
Q Dude
Georgia
My bad. As soon as I hit the send button I realized you probably had already done that. I bought the black one and had it painted.
I just took a panel to my auto guy and he color matched it. I looked into all the CARC stuff....decided to just color match it.
Where did you get your Half windshield from May I ask? I have a 2017 Diesel MRZR Will that same windshield fit mine? Thanks 👍🫡
DaveSC
15
West Virginia
When I bought mine at the USMC logistics base in GA, the dufess said CARC stood for Carcinogen. Looked up CARC when I got back and it means radar absorbing paint.
Bsuit
Tennessee
My 2017 MRZR-D4 is overheating. It has a new fan, relays and fuses. When the machine reaches 180 degrees the fan begins to jerk and will then make a few rotations and stop again. It will then do the same sequence of jerking, stopping, spinning a few times and then stopping. Any help is appreciated.
nickd
64
Newport, Delaware
i Have a gas powered MRZR, The gas models have a temperature sensor on the block. Since you changed everything else, I would look around the motor for the temperature sensor since you mentioned changing everything else that would be involved with the cooling system
Bsuit
Tennessee
Ended up being a bad alternator not putting out enough volts to turn the fan and clogged radiator fins. Thanks for the help though.
Eltonich
Puerto Rico
Based on drive belt number 3211193, the following belts should be compatible with the MRZR-D4: Gates 36G4246, 36C4246, 36R4246, Dayco XTX228, Sixity belts compatible with the aforementioned belts, and maybe others that I'm not aware of. It's that correct? I've been trying to order Polaris belt # 3211225 through Amazon, but the seller keeps sending belt number 3211148.
