Polaris MRZR-D4
Retiredwarhorses
4,617
Brentwood, Calif
I have a 2017 MRZR D4. I have been told like everyone else that US Federal Regulations prohibit Polaris from selling parts to civilians r servicing these vehicles. I spent a couple weeks in the Army and know that for every rule there is an exception so I started digging. Reaching out to Polaris Defense I was brushed off with the claim that these vehicles are covered by Title 10 U.S. Code. If you haven't delved into this, its HUGE, literally thousands of pages. Oddly, while it does cover the sale of vehicles requiring Govt permission, there is NOTHING prohibiting the sale of parts. Next I researched EVERY contract between DoD and Polaris, guess what... NOTHING there prohibiting the sale of parts either. Now I am really confused and start digging deeper where I found that Polaris internal policy says they will not sell these parts to civilians.
Personally, I am starting with calls to my Senators and congressman to see what pressure they can apply to Polaris. Suggest that other owners raise the heat as well, get your elected representatives involved. What can it hurt, right?
good luck with that….while ur at it, see if you can get them to sell us JLTV’s as well.
Retiredwarhorses
4,617
Brentwood, Calif
the engine doesn’t crank, nothing to do with a dead spot in the starter, it’s as if the truck is being started in gear or like a bad neutral start switch.
if you leave the key in “start” and push the brake pedal, you hear a click, like activating
a switch of some sort, the engine won’t start unless the brake is depressed by design, in park or in neutral.
How would the blackout switch affect starting?
fixed the starting issue, here is the aftermarket starter off amazon for $128
nickd
64
Newport, Delaware
There is one on Facebook not me, don’t know the guy. I have a few of the other style, since the bolts are steel and the rims are aluminum there is a chance some of them will snap as you attempt to remove the old tire.
DaveSC
15
West Virginia
Nickd, Thanks, contacted him. He is getting a shipping quote from Alabama to me.
DaveSC
15
West Virginia
OSP
I had a problem with a Govt agency. Wrote a letter to my congressional Rep. Cleared the problem up. I guess Govt agencies do no like Congressional visibility. She stated on her website, she cannot force an approval but she can require them to respond with an explanation. Everyone, write that letter or email. About the Marine Corp and Polaris. We had to fill out that SF form to show we are American citizens, we should be able to by repair parts. Dave
DaveSC
15
West Virginia
Nickd
Wheel is on its way. Thanks bud!! $165.00 for Wheel, $55.00 shipping to me from Alabama. $220.00 total. FedEx, will be here in three days. The owner is an Army CSM NatGuard. Nice guy.
Now I'm researching batteries. MRZR-D4 has two, both original 8 years old. They are like motorcycle batts. Group 30L. I think I am going to go with AGM (glass mats) versus lead-acid.
I have to figure out a high lift jack, and lug wrench, and where to mount them. The spare tire is going to live in the right rear above the engine standing up. Some guy on Ebay is asking over $900.00 for a MRZR spare tire mount. Too much. I might put the jack on the roll cage above the rear seats. Need to figure out a tool box.
aceecaus
Republic of Texas
Nickd
For batteries, check out Continental HDX-30L
The hi-jack lift mounts to the rear bumper
for spare tire mounts, just throw it up top...
jamesddsemaj
Hawaii
Post or DM your VIN and I'll check. I could go by model number but I'd much rather make sure, small things can change between models and may send you to order the wrong parts.
live in Maui Hawaii and recently purchased an MRZR and then discovered that I can’t get parts. In searching for information I ran across your posts and you seem to be the only person that I know of that can get parts. It would be greatly appreciated if you would be willing to help me? I tried to message you, but it would not let me.
publicenema
35
Ottawa, On, Canada
Got your PM and sent you info on how to get ahold of me.
The spare tire mounts are pricy. The mil spec tires are 12 ply bead locks and run flat.
The mounts aren't terribly expensive, unless you're buying used ones on eBay. The OG 12-ply DWT runflat tires are getting harder to find, not sure if they're made anymore. They are particularly knobby, and I've noticed more recent auctions switched to a different tire that looks like it probably runs smoother than the runflats if you're not planning on running it through serious trails.
Nickd
If you can find more rims at that price, buy them all up - the D4s (and the gassers run the same rim specs) are almost 4 or 5 times that price new. Just be careful with the bolts, they can seize in the rim. make sure you apply anti-seize to them and torque them.
The AGM battery is the right call. Won't have to worry about gassing and terminal corrosion.
For the High lift jack, the polaris kit is just rebranded hi-lift stuff. Everything is available on their site @ hi-lift.com. Jack is the UTV-424, mount kit is TM-700 and is mounted as pictured by aceecaus. If you want to mount it on the cage, I believe you'll need the larger mount kit TM-750. Just a word of caution, everything becomes a missle when you crash. I would not mount a jack anywhere behind passengers where it has the potential to strike them in a collision.
Regarding your lug wrench - if you buy the OEM polaris spare tire carrier, the hold-down handles are also a lug wrench on both the military and civillian versions of the spare carrier
WWIILBird
17
Northern NJ
Picked up my 2017 Polaris MRZR-D4A1 this week from Albany, GA. The diesel engine starts after cranking and pumping the pedal a few times. Starts after the initial start ups are quick and smooth. I'll order the manual shortly.
Question for the group, today I started the engine and was going back and forth in my driveway and as I was backing up the amber check engine light came on and the gas pedal was unresponsive. The unit would only idle in gear. I switched to park and neutral and stepped on the gas pedal and it wouldn't rev up. I turned off the engine and restarted about 10 minutes later and it was back to normal for a few minutes then the check engine light came on again the gas pedal again was unresponsive and the engine was just idling. The display window didn't have any codes, just said check engine. along with the amber check engine light. Any suggestions on where to start focusing on? Thanks
DeMilitarized
1,116
Gainesville, GA
You likely have internal damage to your wiring from your pedal to the ecm. Not sure if the MRZR runs can bus but if it does then I would look for missing resistors in the can bus or broken and lose wires.
aceecaus
Republic of Texas
If you can get a digital wrench, it'll tell you why the check engine light is illuminated and it'll help narrow down the issue. I bought one a few years ago and it was the best money spent. It's helped my track down issues on 4 different machines, plus on two friends machines also.
WWIILBird
17
Northern NJ
Just googled what a digit wrench is. Are you referring to a Polaris Digital wrench?
found this link but it doesn’t include the software.
Can you point me where you got yours? Thank you!
