Polaris MRZR-D4
publicenema
35
Ottawa, On, Canada
Thank you very much for finding that model number. Primary and secondary clutches, drive belt, alternator, and the fuse block label from under the seat if available. Maybe more later as I go along
drive clutch has two options depending on date of manufacture. You'll have to look at the label on the right forward frame rail and reference it to make sure you order the right parts, make sure you don't lose it.
1323443 ASM-DRIVE CLUTCH,DSL,M [INCL. 2-11][TO 9/17/2018]
1323692 ASM-DRIVE CLUTCH,DSL,N [INCL. 2-11][FROM 9/17/2018]
driven clutch, same as above. reference date of manufacture to ensure correct part
1323444 ASM-DRIVEN CLUTCH,DSL,M [INCL. 2-16][TO 9/17/2018]
1323711 ASM-DRIVEN CLUTCH,DSL,MI [INCL. 2-16][FROM 9/17/2018]
drive belt
3211225 Belt, Drive
alternator
3023106 ALTERNATOR
Forward fuse box label: 7183782 LABEL-FUSE BOX
Rear fuse box label: 7183783 LABEL-FUSE BOX
gottaluvit
Alternator and drive belt were achievable. Got last new oem alternator a seller on ebay had (on buy it now status) for $200 less than any others I saw. It looks very hard to find the clutches or the fuseblock label. Not a photo on the web of the label that a google lens search or the part number search can find. I looked through all of the upcoming and sold MRZRs whete these come from and not one clear photo of it. I have one thats close to clear. Was hoping some eagerly kind person would pop their rear left seat up and take a photo of that label. I got one close enough to differentiate between where relays go vs where fuses go at least.Screenshot_20240720-114953.pngScreenshot_20240720-114953.png
publicenema
35
Ottawa, On, Canada
Sorry for the delay, here's the power distribution panel layouts as requested:
Guyfang
27,256
Burgkunstadt, Germany
Post this picture in the TM upload forum. Explain what it is. And what its for. This is something lots of folks will might want to see, and to hide it here in this thread is a crime. No one will ever find it again. Thanks!
publicenema
35
Ottawa, On, Canada
I'm a new member, not familiar with that forum at all. Keep in mind that these pics are of a commercial publication, and I don't think the mods would like that uploaded here.
Edit: didn't realize you were a mod. Feel free to download them and share to the other forum, with labelling if you wish.
gottaluvit
Here is a picture with two rows removed. I did notice the small numbers denoting the connection post numbers on the pics of the fuse/relay locations. Would anyone happen to have a chart denoting what the post numbers apply to? I saw one on a civi polaris rzr site but that wouldn't apply here on these units
publicenema
35
Ottawa, On, Canada
Thank you
in the pic you posted, the bottom left is upside down.
Also, the box is setup incorrectly. Top left is correct for a relay. Below top left relay is supposed to be a 20A circuit breaker, not another relay. Follow fuse / relay centre #2 diagram I posted earlier and you'[ll have it filled out properly. If it makes it easier to visualize, break down the module pins into columns of two and fill it in left to right using the diagram I provided.
Edit:
From top left:
4 pin breaker
20A fuse or circuit breaker
BLANK
next column of 2 to the right:
BLANK
15A fuse
4 pin relay
Next column right:
RELAY
5A fuse
*optional 5A spare
Rest of your box appears setup ok from what I can see
gottaluvit
Edit:
From top left:
4 pin breaker
BLANK
BLANK
15A fuse
4 pin relay
Next column right:
RELAY
5A fuse
*optional 5A spare
Thanks a lot. I havnt straightened out the previous mess yet. Some of the breakers were half in place when I first looked in. I just removed a few to show the way the relays can be put anywhere. All Polaris had to do is put the labels on the inside of the lid. I ordered new breakers after realizing the larger font numbers are the ones to go by. I will clean this mess up when they come in and clean all the connectors as well as use dielectric grease.
