74M35A2
- 342
- 83
- Livonia, MI
Oops. Beer goggle posting. Wrong thread, fixed.
Naw man just a mechanic that sees how engineers screw things up constantly, and you will need much thicker skin if you thought that was negative.wow, so negative.
Yeah you are just the shoe smeller and ball licker at the bowling alley! Get to twisting wrenches discoball! I would like to at least see you put in the rear window this year.I’m not an engineer, I work at the bowling alley. Davis is a good guy. I just drive him, and most others, nuts sometimes.
The OP wasnt referring to a broken transmission. His thread was in relation to the military mwo to add abs to the trucks. The engine stalled and steering is lost when the brakes locked up stalling the whole driveline. Hint as to why your truck has abs
https://youtu.be/PvW9ISZ6LlM
Sent from my SM-G965U using Tapatalk
How are you keeping your truck from rolling over?Simple enough. Many people who collect these trucks have tons of experience on how to handle such a beast. Flip the coin over and you'll find Soldiers of any kind of background. I've met some who never had a driver's license in their life but now operate big trucks. The M939 series trucks biggest flaw was possibly the automatic transmission. So easy, anybody can drive one! Prior to that, you had to know what a clutch pedal was and how it was used in a medium series truck. I always treat mine as if it's the most dangerous thing on the road, give myself plenty of time to brake and so far have kept everyone safe. My youngest son even hangs onto the bar in front of the dashboard while underway.
Driving as responsibly as possible and avoiding panic braking scenarios. I have also familiarized myself with how the truck feels under threshold braking on quiet country roads. Through this I learned to lower my rear tire air pressure from the 70 psi called for in the technical manual down to 35 psi when running unloaded. Prior to lowering the air pressure the rears would chirp under hard braking which is indicative of the ABS module attempting to keep the truck from locking the rear wheels completely. Now with the air pressure lowered in the rears, it stops hard and evenly when needed. It's a good exercise to try in a remote area. I mostly stick to my first rule though, drive responsible and avoid panic brake scenarios. I constantly scan traffic ahead and around me, something my Dad really instilled in me once I started riding motorcycles. Treat all traffic as if it's going to do exactly what you don't want it to and have a plan to react. It's not a 100% solution but it certainly helps.How are you keeping your truck from rolling over?
