Power Steering Pump Question
Zeus51
35
Birmingham, AL
Working on a m1009. I have a donor m1009 that ran before starting to pull parts from it. I used the functioning power steering pump from the donor that was not having issues. I installed it on my project m1009 and it drives and functions. BUT, when I turn the wheel to lockout, the fluid spews out of the top of the reservoir. I’m working on it alone, so I’m unable to tell if the pressure is popping back the fill top or if the neck is cracked.
Has anyone seen this? Does it mean the pump has gone bad?
WWRD99
1,388
York Pa
I have seen this before and it typically has air bubbles in the fluid from the initial start and/or it is over filled. Once it sits for a bit the air bubbles should go out and can fill it to the proper level.
Zeus51
35
Birmingham, AL
Thanks! I thought I bled the system well but I guys it’s possible I didn’t. I’ll let it sit for while and then try again.
