WPNS421
- 3
- 0
- Cantley Quebec
Up here in the far north it was a beautiful day, about 29 degrees and we decided to start all the MVs. All the CUCVs started no problem, and then the M109 and the M35. We didn't even need the booster cables. The trucks were warming up and all was going well till we noticed an oil leak on the M35, we stopped the truck and checked to see what the problem was.
The truck has the new spin on filter adapters and the M35 was leaking from the adapter. We had a similar problem this summer and we removed the filter checked for damage on the filter all was good and we then checked the adapter and everything appeared normal we changed the filter and retightened everything, the leaking stopped but we had a little seepage.(very minor)
What we think is happening is that the aluminum adapter has contracted due to the cold and the filter is not seating properly. We will be checking this out as soon as we get a chance. Has anyone else had problems with the adapters.
This is a heads up for anyone that uses the adapters
