First time posting for some help, I have a 2002 M1045A2 with 6.5 . Truck started , idled, and drove like a Swiss watch, and then got a leak in the mechanical fuel pump. I removed it , ordered the new pump and installed it 2 weeks later. After install I cranked the engine and it started right away and stoped, I had to crank it a few times to fill the fuel line up. So now the truck is not the same at all !!
1: I have a lot of white smoke after cold start continues for a while ( Which I never had before )
2: after startup I have a rough idle ,stumbling like for a few minutes and then goes away
3: if I don't start the truck for a few weeks it will start at first crank and them stop and it will take a few cranks to start it again
I never had these symptoms before pump change.
All I did was change the fuel pump didn't touch anything else , have I missed something in my repair of the pump?
Thanks in advance
Thanks in advance
