- 513
- 13
- 18
- North Georgia Mtns.
Re: RE: Push button light switch
What is the "get me home" feature on the old lever 3 way? I know "back in the old days" when cars had the push button dimmer on the floor.... If the dimmer went bad then you could hold the switch down with you foot to keep the lights burning. Better have some leather soled shoes or boots because that switch got mighty hot being held closed.Jones said:The early push button switches had problems and occasionally set themselves on fire.
The biggest problem we ran into was when the switches were installed and the ground wire was not connected first, as there's a little mini-computer inside that's static sensitive. I suggest carrying a three-lever for a back-up as the push button switches have no get-me-home feature
Once installed and initialized by pushing any button, they work by pressing the mode you want then pressing the enter button within five seconds. The keys are back-lghted amber and there's a blue indicator light on each button that's lit when that mode is on. To turn everything off push the all off button followed by enter and after about 20 seconds of delay it turns itself off.
