banditt1979
- 738
- 93
- Cincinnati, OH
I am looking to install a pyrometer, maybe 2, in my duece. You guys have any recommendations? I'm skeptical of the units for sale at amazoniano. Thanks in advance!
I’ve had my fuel turned up at one point where I could boost around 20psi or higher (if I wanted) and my egt’s hadn’t climbed to high yet to be concerned with heat, but I was concerned about the boost popping a head gasket OR tossing a rod.Where does everyone hook up their boost?
What is the max limit boost for a LDT465-1D?
When/why is it necessary/recommended to install a boost indicator? EGT I get.
Considering the majority of the LDT motor is the same as the LDS, there would seem to be little concern in over boosting an LDT, within reason.
What am I missing/not getting?
Pricey little gauges! Nice!I decided on a hewitt.
Started to take things apart thinking I would remove the turbo but the more I look at it the more I think I will break all the bolts attaching it to the manifold. That would be my luck so I would like to do it on the engine while running. Anyone have any advice/warnings/stories?![]()
I think I just found my next project! Having the two gauges together should make for some good info for diagnostics.I’ve had my fuel turned up at one point where I could boost around 20psi or higher (if I wanted) and my egt’s hadn’t climbed to high yet to be concerned with heat, but I was concerned about the boost popping a head gasket OR tossing a rod.
As for where I hooked my boost line, there is a small 1/8” plug on the intake manifold elbow.
