- 6,426
- 4,986
- 113
- Ft. Lauderdale, Florida
Is this the same for 5 ton and the 2-12 ton Deuce?
The -12 for both the 2 1/2 and 5t states remove both plugs, install grease fitting and fill till grease appears at other hole, there HAS to be a reason for this instruction in every -12 for all the 2 1/2 and 5ts other then just venting, if that was the case, only one plug would need to be removed and no grease fitting would be needed.Pump the grease through the zerk fittings to push out the old grease from the kingpin bushings; the plugs are opened so you don't blow out the boot.
Ron, you are correct. However it's been my experience that filling from one side to another overloads the knuckle with grease, and I've blown out several boots that way...I don't go through water much so I add grease via the zerks on top & bottom (through the kingpins), just a few squeezes each, with the plugs open to vent. I've finally gone more than a year & 5K miles without blowing a knuckle boot.The -12 for both the 2 1/2 and 5t states remove both plugs, install grease fitting and fill till grease appears at other hole, there HAS to be a reason for this instruction in every -12 for all the 2 1/2 and 5ts other then just venting, if that was the case, only one plug would need to be removed and no grease fitting would be needed.
Do you know if the axles are interchangeable ??Is there anyone with a 60's model truck. I looked and I only had late 70's trucks. The Diff. tag say Rockwell on top and Rockwell International on the bottom. These are the newer Ujoint style. If it has Rockwell on top and Timken on the botton of the tag I do believe they are old style CV or the ball type .
How many licks does it take to get to the center off a charm pop and how many pounds of grease does it take to blow out a boot?Pump the grease through the zerk fittings to push out the old grease from the kingpin bushings; the plugs are opened so you don't blow out the boot.
I should clarify that for the U-joint style axle shafts, less grease seems to work better. It seems that too much grease near the boot, when steering, results in the grease being forced out via tearing the boot; as the steering knuckle turns, it compresses the grease through the boot, if there is too much accumulated already inside the knuckle area.How many licks does it take to get to the center off a charm pop and how many pounds of grease does it take to blow out a boot?
Does anyone think the maybe the Goverment maybe just once had an oversight and forgot to update the TM's when they switched to Ujoints. Oh yea that could not happen so forget that.
You're right, I'm wrong...I was thinking of the grease outside the spindle.Ok please tell me what do you think your greasing when you have ujoints and you load up the knuckle? There are no bearings that get greased, I realy don't think that the grease will make the spindle bushing. The upper and lower bushings for the knuckle ( king pins ) only need a little once and awhile and you don't have to knock out the old grease from the knuckle upper or lower bushings as they will not take on dirt. Then there is the needle bearings in the ujoint and there is no way any grease will get into them no matter how many boots you blow out.
