Quick Start metered dose ether injection
1,184
I agree, and once you have seen the difference, it would be hard to not agree. I'm glad you have a full system and are happy with it.
deathrowdave
84
falmouth, ky
That propane cylinderr contains LIQUID PROPANE if turned upside down you will be getting liquid propane . Liquid will be introduced into the combustion chamber were it changes state into vapor.Problem with using propane is that the density of propane vapor is greater that air . ( Air =1 Propane vapor =1.5 ) If your engine does not start or you have a leaking valve you could fill the crankcase with propane vapors,that could explode upon ignition (starting) the engine . Instanly removing the oil pan !!!!! Have a great day and be safe !!![thumbzup]
greenjeepster
10
Southbury, CT
Dave:
It is metered dose... It will not get any more than 6ccs of propane or any other liquid. I should of tried MAPP while I was at it.
Faulty valve would be a risk with anything including ether.
deathrowdave
84
falmouth, ky
I have experienced this happening with a Cat D8 remved the oil pan !!! Ether and Mapp lighter density than air they will rise and evaporate , Propane is heavier and will collect in the crankcase !!! 30 years experience with Propane have 8 million gallons on hand !!!Just be safe it will frostbite , boils at - 44 F !!! Dave
saddamsnightmare
80
Abilene, Texas
January 29th, 2010.
Makes me appreciate the intake heater system..... When it works, it's just a shot of diesel fuel and no replacing ether cans. The measured shot system does have its advantages over shooting it in the air intake..... too much ether and you have a dead diesel, as they really don't like ether all that much. What I have never figured out is how the deutz diesel make do without ether and start without glow plugs or other aids down to -20*F ((Air cooled FL912-4), whereas the American diesels seem not to be able to function at low temperatures without assists.....? I guess after the trip to Moscow in WWII, their engineers just figured winter happens?
Cheers,
Kyle F. McGrogan8)
dittle
72
Albia, IA
January 29th, 2010.
Cheers,
Kyle F. McGrogan8)
Its all in the design of the engine. We used to have a Deutz 7085 tractor on the farm so I know what your talking about. Might have something to do with the compression ratios as well??????
