Quieting down the low air warning buzzer?
simp5782
Feo, Fuerte y Formal
9,504
Mason, TN
My truck doesnt have a buzzer or a light. guess someone already got pissed at it and chunked it out someplace!
Jesse6325
Orange Grove, TX
I know it's annoying but trust me, that buzzer is your friend.
Just start the truck up, Make sure you have oil pressure and take the time to do a good walk around.
By the time you get done checking everything you should have enough air pressure that the buzzer should be off.
If it's still going then either
1. you did not do a very good preop,,
or 2. You have a major air leak and are not going anywhere until it's fixed.
F18hornetM
11
Ocean City, Md
I honestly dont see the big deal. Its no louder than the whole truck running. Its there for a reason. While its buzzing, is a good time for the engine to warm up some. At least a little. I like the light idea, but would still have the buzzer. Its like safety switches/devices on equipment can be a pain in the butt, they are also there for a reason. Somethings just aren't worth screwing with in my opinion.
wsucougarx
Washington State
Hmm, I must be a sick individual or something but the buzzer doesn't bother me. In fact, I have accepted it as part of driving MV's. It is definately a peace of mind to know if that buzzer should ever go off, I won't mistake it for something else. Instead, that'll be my queue to pull the heck over ASAP. I did install the Low Air Warning Light, not to replace the buzzer, but rather to accompany it.
Plus I also think of it as a possible anti-theft device. Should an unknowing thief, not knowing about the buzzer, gets far enough to figure out how to flip the master switch, will likely have a surprise. I think that buzzer should scare anyone away not expecting it;-)
tco3129
Flat Top W.V.
As everyone has said, it's your friend. If I'm working on the truck and need the power on I simply reach under the dash and unplug it. Also the first thing I reconnect before finishing up.2cents
PsycoBob
11
Auburn, NY
I'll shortly be adding a momentary 'stfu' button to trip a spdt relay, powered by the low-air switch. As long as the switch provides power after I hit the button, relay stays powered & disconnects the buzzer. When the switch turns off, relay resets & buzzer operates normally. A light will be powered directly from the low-air switch.
My truck's quiet enough with my huge muffler & anti-rattle upgrades that the buzzer is audible from halfway down the block. It's definitely meant to be heard thru earplugs.
If I remember I'll make up a wiring diagram later.
Rustygears
Ramona, CA
Current DOT requirement is to have at a minimum a visual warning device like a light or wigwag. The buzzer is optional. With that said, I like the buzzer because I keep my eyes on the road and out the window, not on the dash! Needless to say I have both buzzer and light and will keep'em.
Trango
23
Boulder, CO
If the sound of the buzzer is too much, why don't you guys just switch the "off-on" switch to "off" while the truck is warming up and building pressure? You'll have to switch it back to ON to get functional indicators and headlights, and since those are noticeable when they're not working, even if you forget to turn the switch to "on" when you start driving, you won't have the switch in "off" for long.
Best,
Bob
135gmc
St Paul/MN
I've always found that there is enough noise in the cab that the low air pressure buzzer isn't much of a problem. The truck's air compressor puts out enough air that it shuts up pretty quickly, plus the waiting time lets the truck warm up a bit, plus you have time to walk around and look for odd noises and leaks before you move out. My hearing hasn't gotten better with age, so I added the dash light as well. The buzzer & the light are cheap insurance.
PsycoBob
11
Auburn, NY
Insulated cab + hardtop + MUFFLER (too big for little letters) + 3ft of stack + cab overhang from water body + turned-out exhaust + radiator cover + rattle-pads + WMO fuel = quieter truck at idle than a CUCV, by a LOT. Unless you stand in front of the radiator, it's downright sneaky. The neighbors don't mind me idling to cool the turbo like they did with the whistler. :whistle:
Quickfarms, I need a napkin or something to draw on.
Here we go. Javascript online circuit simulator, even lets you play with it. Upper switch between +24v and relay is low-pressure alarm. Resistor is the buzzer- they didn't have a normal one. STFU-button is the switch on the bottom. To make the simulation start, flip the upper switch & push the lower one.
I'm not sure if the actual deuce system grounds the switch to make the buzzer go off, or the reverse. Not that had to modify.
Here
1 Patriot-of-many
87
Zimmerman MN
Best,
Bob
Is this a trick question? Or are the A2's different than the A3's? Buzzer and lights on the A3 are dependant on the accessory switch. Starting the vehicle is dependant on the accessory switch. Is there no accessory switch on A2's? What am I missing here?
Trango
23
Boulder, CO
At least with the A2, you need the switch on to start, but then you can flip it off while pressure builds. I'm not sure if the a3 uses any sort of fuel solenoid or if the engine needs 24v+ to run.
