SCSG-G4
PSVB 3003
- 5,403
- 3,508
- 113
- Lexington, South Carolina
Had a problem with my radiator last spring and got it rebuilt, no problems till late November. Then it started dripping, so we ran a pressure test, drove it around some, etc. No leak. Went to check on it again this morning, leaking again, but I had better light and looked to see where it was coming from. Took a minute or so, but I finally noticed a wetness on the front of the lower radiator hose right at the radiator, not on up the hose or on the radiator itself. Cranked the truck up and it stopped leaking by the time I had air pressure.
Common denominator between the latter half of November and last night - it was below freezing. First thing is to tighten the clamp a bit and see if it (the leak) continues, but a trip to NAPA is also planned for a new hose.
