Radiator (hose) Leak
SCSG-G4
PSVB 3003
5,399
3,490
Lexington, South Carolina
Had a problem with my radiator last spring and got it rebuilt, no problems till late November. Then it started dripping, so we ran a pressure test, drove it around some, etc. No leak. Went to check on it again this morning, leaking again, but I had better light and looked to see where it was coming from. Took a minute or so, but I finally noticed a wetness on the front of the lower radiator hose right at the radiator, not on up the hose or on the radiator itself. Cranked the truck up and it stopped leaking by the time I had air pressure.
Common denominator between the latter half of November and last night - it was below freezing. First thing is to tighten the clamp a bit and see if it (the leak) continues, but a trip to NAPA is also planned for a new hose.
jfnemt1ff1
Higgins Lake Mi.
I bet you are on the right track with the hose clamp. tighten it when the engine is at nprmal temp. When I used to work on cars we would see that alot when the temp. got cold.
John
jatonka
111
Ephratah, New York
For sure, in the cold weather all the coolant hoses need a tightening. On any water cooled engine. Clamp "em down good and you will be all right. JT
littlebob
26
Baton Rouge LA
I always notice the smell of antifreeze in a parking lot when it first starts getting in the thirties here. Usually around older cars that probably hasn't had the hoses changed or clamp tightened in over ten or fifteen years. I think a lot of our trucks would fit into that category.
littlebob
