radiator repair
nickd
64
Newport, Delaware
Well the radiator started to piss fluid before Aberdeen so I took it out and had it repaired inorder to bring the truck to the rally. On the way home same thing pissing fluid until the temp reached 200 degrees then it never moved. Once again out comes the radiator and back to the shop for the second repair(no charge) While the radiator was being repaired i changed the air lines to the new plastic ones. radiator back in and SOB it leaks again!
Consulted with Marksgarage2, purchased 1lb of black pepper and will try the black pepper fix next. I do not want to pull that radiator a third time unless I replace it!
Bitching is over
1,827
Same place Nick? Can you see exactly where its coming from? Stupid question but are you sure it's not the weep hole in the bottom of the waterpump?
