RAPCO Spray Can paint issues
Keith_J
1,323
Schertz TX
Yes, Mike, that will work to clear the internal straw of congealed pigment. Ounce of prevention would be to store the cans upside down.
i have blown out he straw with compressed air and those little plastic cone inflators that come with cheap compressors. This trick also works when running low on propellant in the can. Be careful, the maximum pressure in the can is only 30-50 PSI.
bonedoc
Bangor, PA
Glad I found this thread as I'm getting ready to order my Rapco tan and black to finish the 3 color camo on my deuce. That mixkwik looks really cool. worth the money!!
3dAngus
101
Perry, Ga.
Funny! I'm out back using the mixkwik now, where I bought it after reading this thread. I've had it for about a month now and used it several times already.
It really works, but,.... be darn careful not to fully pull that trigger. It is not the best made tool and I'm afraid it might come apart if I do, where the instructions say over and over, be careful not to give it full power. Just a gentle touch of the trigger will do.
Also love his commercial at the web page, "Mr. Tool Belt"
Going back outside to paint some ammo cans now. Mixkwik carries my recommendation especially to eliminate some of the issues with Rapco paint.
I've always preheated the cans with an incandescent light for a couple of hours, then shake thourally, and have never had a problem. If its 95 outside and 85 in the garage, there would be no need to heat them up.
I don't use Rapco on my ammo cans, but I wouldn't use anything else on my MVs. Good stuff if used right.
MR3C
Australia
what is the quality of the Rapco paint in terms of being hard wearing, resistant to chemicals/fuel/body oils, etc?
WingCO
Dallas, Texas
I've been using Mark's paint for years with very few problems. I take a couple of cans with me on the road to rallies, etc., and they work great for last minute touch ups.
I do the same thing that others do when they put the nozzles in thinner - but I use Xylene - and I put some on the top of the spray can to keep it clean as well.
This paint is heavy and it's normally applied, insofar as I know, with a standard sprayer and compressor system. To me, rust and corrosion control is a constant battle so I have to strip and repaint some small areas occasionally.
Personally, I like RAPCO and their paint. (I didn't get paid for this either). Can you tell me someone else that makes this stuff whose rattle cans don't clog?
WingCO
Dallas, Texas
I have found the wearing qualities to be fair to good. I stripped and completely repainted my M35A2C and my M105A2C and used RAPCO paint for it. I used as standard auto type primer first and then did 2 coats with current tan. I have to touch up dings and some deep scratches sometimes, but I've never had a problem with fuel, oils or other fluids. Even after the paint is set and dry, Xylene doesn't seem to phase it too much.
