re-wiring my MEP-004a for different voltages, including single phase
rustystud
3,376
Woodinville, Washington
With this 10 lead generator the way R Racing has it connected is the only way you will be able to use 240 volt single phase. By using 2 of the main leads out to power your furnace you will need to use the third to power something of equal value. I know there is a way to run a "low zig zag" WYE circuit from this generator I just cannot find the diagram. You cannot run the "double Delta" though.
R Racing
St. Leonard, MD
Another way if that doesn't work is in front of the switch is the throttle control. Pull on the throttle it will Rev a bit and if you go about 100 to 200 rpm higher it should go into overspeed and shut off.
Wh6czu
Kentucky
I got it off, had to crack open the fuel line . Dead crank switch didn't work or over rev... Guess I'll have to fix this problem before moving on
R Racing
St. Leonard, MD
Hi Jim it's not that it would hurt it the engine. It's that the air system the way it's routed thru that unit. You would be hard pressed to find a way to get in there to block it
R Racing
St. Leonard, MD
And are you making any DC voltage? . Flashing the field is easy. Start the generator. Get it up to speed. Then turn the starter switch as like your starting the engine. If all is good you will see the frequency and the voltage peg then stabilize. If it drops off then you have another issue.
Triple Jim
334
North Carolina
Ha, OK thanks. I read it as if you said "It's hard on the equipment", rather than "It's hard to do."
