Brent.Cain
- 1
- 0
- Canal Winchester, OHIO
I really like my blue torch fabrication disk brake set up it allows alot more adjustment as you go taller with a lift and ur pinon angle goes up
Buy the brackets then get calipers and rotors and brake lines from your local parts outlet with or without parking breaks way cheaper! Do the hole thing for about 350.00. I myself remove the ball in the proportioning valve to the rear, equalizes the brakes front and rear! not only makes for better brakes but also cuts about 65 lbs or more.
who needs emergency brakes you have an auto trans
What angle should it be at and how? bend the mount? make new link?My M1028 does indeed have the factory load-proportioning valve. I didn't touch it and everything works perfect. The only time this would need to be modified is if the truck was lifted.
I explained this in detail in post #75 of my rebuild thread. There are two things that you should pay attention to - 1.)- the little dot on the valve needs to be positioned at 12:00 with no weight in the truck, and 2.)- the angle of the two actuating arms needs to be at or close to 90 degrees with no load. The dot on the valve can be adjusted by simply removing the nut and pulling the short arm off, rotating the valve to the correct position, and then reinstalling the short arm and nut. A longer arm, if needed to accommodate a lift, can easily be fabricated by picking up a piece of 1/8" x 1" steel bar stock from the hardware store and cutting it to the appropriate length and drilling new holes.What angle should it be at and how? bend the mount? make new link?
