Rear Halfshaft to Geared Hub Leak
GMVguy
108
Texas
Just noticed the rear halfshaft is seeping. Fulled it up with Gear Oil but planning to take a closer look this weekend. Anyone got a suggestion for the part numbers for seals, etc. I should buy to prepare for the job?
Thanks,
DatGuyC
22
Essex, Maryland
One of the first things I did when I got my truck was replace all the hub seals. You can look for packs on ebay that come with both that top inner seal and the larger bottom outer seal for the spindle, plus the lock washer and new seals for the plugs. After you remove the half shaft I recommend tapping the seal retainer out from the outside where the half shaft bolt goes instead of trying to pry it loose where the shims are so you don't destroy the shims. For tapping the new seals in I took the new seals to home depot and found pvc pipe couplers that had about the same OD so you aren't beating on the seals directly.
GMVguy
108
Texas
Great advice, thanks. I'm going through the TMs now to determine the part numbers needed. Is TM 9-2320-335-13&P the best one to use?
TedG
39
MI USA
The diff output seal is amg specific. There is also a small filler seal that goes behind the shaft nut. Use a dab of Silicon to help seal and always use lock tight on nut.
For seal installation, crimp new seal in a bit to form a taper so it goes in straight.
use new Norlock washers and new half shaft bolts to...with locktight.
