Jeepsinker
- 336
- 83
- Dry Creek, Louisiana
X2. No need to tear that transmission apart. And you can probably get that snap ring from any transmission shop that deals in standard transmissions, not just automatics.
I would make sure that it was replaced with the correct bearing, in that it is shielded, on the inside. NTN/NSK part number: BL308 ZNRPrevious owner had the input bearing fail. .......................
remove top cover of trans before removal from truck. 300% easier to pull trans then.Borky, this was my first trans pull and rear seal replacement. Took me about four hours to pull trans first time, and about an hour and a half this time. After removing propeller shaft, put trans in first. Give you some room to pull back trans as you remove it. Lots of great help here, use it!
